Salta al contenuto principale
Mr. Coffee DW13 O Ring Replacement
Cosa ti serve
  1. Mr. Coffee DW13 O Ring Replacement, Base: passo 1, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement, Base: passo 1, immagine 2 di 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 O Ring Replacement: passo 2, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement: passo 2, immagine 2 di 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 O Ring Replacement: passo 3, immagine 1 di 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 O Ring Replacement, O Ring: passo 4, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement, O Ring: passo 4, immagine 2 di 2
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Mr. Coffee DW13 O Ring Replacement: passo 5, immagine 1 di 1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 O Ring Replacement: passo 6, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement: passo 6, immagine 2 di 2
    • Use needle-nose pilers to pinch and loosen the crimps
  7. Mr. Coffee DW13 O Ring Replacement: passo 7, immagine 1 di 1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 O Ring Replacement: passo 8, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement: passo 8, immagine 2 di 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 O Ring Replacement: passo 9, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement: passo 9, immagine 2 di 2
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  10. Mr. Coffee DW13 O Ring Replacement: passo 10, immagine 1 di 2 Mr. Coffee DW13 O Ring Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Compra
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 10-31, Maness Winter 2014 Membro di Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,018
