Salta al contenuto principale
Introduzione
This is an easy replacement. All you need to do is open the top of the coffeemaker, move a black plastic arm, and lift the filter out of the machine.
  1. Face the top of the coffeemaker towards you.
    • Face the top of the coffeemaker towards you.
  2. Identify the two tabs on top of the machine. Lift the top of the coffeemaker up, using these tabs
    • Identify the two tabs on top of the machine.
    • Lift the top of the coffeemaker up, using these tabs
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Slide the black spout towards the back of the coffee maker, exposing the filter. Slide the black spout towards the back of the coffee maker, exposing the filter. Slide the black spout towards the back of the coffee maker, exposing the filter.
    • Slide the black spout towards the back of the coffee maker, exposing the filter.
  5. Using the side tabs, gently lift the filter up and out of the machine. Using the side tabs, gently lift the filter up and out of the machine.
    • Using the side tabs, gently lift the filter up and out of the machine.
Conclusione
Altre 2 persone hanno completato questa guida.
Tess Bradley
Membro da: 26/01/2014
343 Reputazione
3 Guide realizzate
Cal Poly, Team 10-31, Maness Winter 2014 Membro di Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 423
