Salta al contenuto principale
Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement
Cosa ti serve
  1. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement, Hose Replacement: passo 1, immagine 1 di 1
    • Unplug the coffee maker.
    • Empty the coffee maker reservoir.
  2. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 2, immagine 1 di 2 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 2, immagine 2 di 2
    • Flip the coffee maker upside down.
    • Remove the six 13.5 mm screws from the bottom of the coffee maker using a Phillips #3 screwdriver.
  3. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 3, immagine 1 di 1
    • Remove the base using an opening tool.
  4. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 4, immagine 1 di 2 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 4, immagine 2 di 2
    • Pinch the metal ties with a pair of needle-nose pliers.
    • Slide the metal tie off the metal tube base.
  5. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 5, immagine 1 di 3 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 5, immagine 2 di 3 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 5, immagine 3 di 3
    • Use a spudger to push against the plastic tubing and slide it off the metal tube base.
  6. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 6, immagine 1 di 1
    • Using a pair of needle-nose pliers, pinch the metal ties together and slide the metal tie up off of the base.
  7. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 7, immagine 1 di 1
    • To remove the tube, pinch the tubing and pull until it pops off.
  8. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: passo 8, immagine 1 di 1
    • Remove any debris from the base. If the filter is corroded, remove the filter by squeezing the filter and move it up the base of the tube until it comes out.
Conclusione
JoMax Christensen
Membro da: 11/19/21
165 Reputazione
1 Guida realizzata
Un commento
nice pictures, what is the size and material of the tube?
Dean Taeger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 510
