Salta al contenuto principale
Mpow MPBH063 Daughterboard Replacement
Cosa ti serve
  1. Mpow MPBH063 Daughterboard Replacement, Daughterboard: passo 1, immagine 1 di 1
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Daughterboard Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Daughterboard Replacement: passo 3, immagine 1 di 1
    • Unplug the wire connected to the daughterboard.
  4. Mpow MPBH063 Daughterboard Replacement: passo 4, immagine 1 di 1
    • Remove the silver 10 mm screw from the center of the daughterboard.
  5. Mpow MPBH063 Daughterboard Replacement: passo 5, immagine 1 di 2 Mpow MPBH063 Daughterboard Replacement: passo 5, immagine 2 di 2
    • Remove the daughterboard by carefully lifting the daughterboard out of the speaker with the metal spudger.
    • Use iFixit adhesive remover as directed
    • Before you remove the daughterboard, cut around the edges using the tech knife, and remove the adhesive securing the daughterboard to the speaker.
Conclusione
Jazely Barrera
Membro da: 10/09/18
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 148
