Salta al contenuto principale
Mounting Plate Replacement
Cosa ti serve
  1. Mounting Plate  Replacement, Mounting Plate: passo 1, immagine 1 di 1
    • Hold Ring Spotlight Cam and hold it backward to you.
  2. Mounting Plate  Replacement: passo 2, immagine 1 di 1
    • Remove the screw using the screwdriver and head tool PH00.
  3. Mounting Plate  Replacement: passo 3, immagine 1 di 1
    • Open the top lid.
  4. Mounting Plate  Replacement: passo 4, immagine 1 di 3 Mounting Plate  Replacement: passo 4, immagine 2 di 3 Mounting Plate  Replacement: passo 4, immagine 3 di 3
    • Press the mounting plate button and slide upwards.
Conclusione
Un commento
Hello, hope you are doing well. Does anyone know if we can buy a replacement mounting plate for the Ring Spotlight Cam Battery? Mine is cracked and Ring doesn’t seem to sell replacements. Thanks!
Suresh Ram - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,006
