Salta al contenuto principale
Mountain Bike Brake Lever Replacement
Cosa ti serve
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: passo 1, immagine 1 di 2 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: passo 1, immagine 2 di 2
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: passo 2, immagine 1 di 2 Mountain Bike Brake Lever Replacement: passo 2, immagine 2 di 2
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: passo 3, immagine 1 di 1
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: passo 4, immagine 1 di 2 Mountain Bike Brake Lever Replacement: passo 4, immagine 2 di 2
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: passo 5, immagine 1 di 1
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: passo 6, immagine 1 di 3 Mountain Bike Brake Lever Replacement: passo 6, immagine 2 di 3 Mountain Bike Brake Lever Replacement: passo 6, immagine 3 di 3
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: passo 7, immagine 1 di 3 Mountain Bike Brake Lever Replacement: passo 7, immagine 2 di 3 Mountain Bike Brake Lever Replacement: passo 7, immagine 3 di 3
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
Conclusione
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 119
Tutti i Tempi: 3,663
