Salta al contenuto principale
Motorola i850 LCD Screen Replacement
Cosa ti serve
  1. Motorola i850 LCD Screen Replacement, LCD Board: passo 1, immagine 1 di 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 LCD Screen Replacement: passo 2, immagine 1 di 2 Motorola i850 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Completely remove the outer casing from the phone.
  8. Motorola i850 LCD Screen Replacement: passo 8, immagine 1 di 2 Motorola i850 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 LCD Screen Replacement: passo 10, immagine 1 di 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 LCD Screen Replacement: passo 11, immagine 1 di 2 Motorola i850 LCD Screen Replacement: passo 11, immagine 2 di 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 LCD Screen Replacement, LCD Screen: passo 12, immagine 1 di 1
    • Firmly detach the gold strip using a Tweezer.
  13. Motorola i850 LCD Screen Replacement: passo 13, immagine 1 di 1
    • Prop out the LCD screen using a Small Flathead Screwdriver.
  14. Motorola i850 LCD Screen Replacement: passo 14, immagine 1 di 3 Motorola i850 LCD Screen Replacement: passo 14, immagine 2 di 3 Motorola i850 LCD Screen Replacement: passo 14, immagine 3 di 3
    • Remove the LCD screen from the LCD board.
Conclusione
Andrew Aw
Membro da: 04/08/10
1 Reputazione
2 Guide realizzate
Cal Poly, Team 34-56, Forte Spring 2010 Membro di Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,189
