Salta al contenuto principale
Motorola i710 Back Casing Replacement
Cosa ti serve
  1. Motorola i710 Back Casing Replacement, Battery Cover: passo 1, immagine 1 di 2 Motorola i710 Back Casing Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Back Casing Replacement, Battery: passo 2, immagine 1 di 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Back Casing Replacement, Back Casing: passo 3, immagine 1 di 3 Motorola i710 Back Casing Replacement, Back Casing: passo 3, immagine 2 di 3 Motorola i710 Back Casing Replacement, Back Casing: passo 3, immagine 3 di 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
Conclusione
Carson Meena
Membro da: 10/22/12
16 Reputazione
5 Guide realizzate
Clemson, Team 14-2, Benson Fall 2012 Membro di Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 282
