Salta al contenuto principale
Motorola i560 Microphone Replacement
Cosa ti serve
  1. Motorola i560 Microphone Replacement, Battery: passo 1, immagine 1 di 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Microphone Replacement: passo 2, immagine 1 di 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Microphone Replacement, Side Volume Button: passo 3, immagine 1 di 1
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Microphone Replacement: passo 4, immagine 1 di 1
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Microphone Replacement: passo 5, immagine 1 di 2 Motorola i560 Microphone Replacement: passo 5, immagine 2 di 2
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Microphone Replacement: passo 6, immagine 1 di 2 Motorola i560 Microphone Replacement: passo 6, immagine 2 di 2
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Microphone Replacement: passo 7, immagine 1 di 3 Motorola i560 Microphone Replacement: passo 7, immagine 2 di 3 Motorola i560 Microphone Replacement: passo 7, immagine 3 di 3
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Microphone Replacement, Metal Support Plate: passo 8, immagine 1 di 3 Motorola i560 Microphone Replacement, Metal Support Plate: passo 8, immagine 2 di 3 Motorola i560 Microphone Replacement, Metal Support Plate: passo 8, immagine 3 di 3
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
  9. Motorola i560 Microphone Replacement, Microphone: passo 9, immagine 1 di 3 Motorola i560 Microphone Replacement, Microphone: passo 9, immagine 2 di 3 Motorola i560 Microphone Replacement, Microphone: passo 9, immagine 3 di 3
    • Slightly bend the phone frame to expose microphone protrusion.
    • Gently remove microphone using your fingers.
  10. Motorola i560 Microphone Replacement: passo 10, immagine 1 di 1
    • Once the microphone has been removed, remove the connecting piece
Conclusione
Haley S
Membro da: 03/11/13
10 Reputazione
4 Guide realizzate
Clemson, Team 13-6, Benson Spring 2013 Membro di Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 168
