Salta al contenuto principale
Motorola i450 Boost Mobile Keypad Replacement
Cosa ti serve
  1. Motorola i450 Boost Mobile Keypad Replacement, Back Cover: passo 1, immagine 1 di 3 Motorola i450 Boost Mobile Keypad Replacement, Back Cover: passo 1, immagine 2 di 3 Motorola i450 Boost Mobile Keypad Replacement, Back Cover: passo 1, immagine 3 di 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Keypad Replacement, Battery: passo 2, immagine 1 di 3 Motorola i450 Boost Mobile Keypad Replacement, Battery: passo 2, immagine 2 di 3 Motorola i450 Boost Mobile Keypad Replacement, Battery: passo 2, immagine 3 di 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Keypad Replacement, SIM Card: passo 3, immagine 1 di 2 Motorola i450 Boost Mobile Keypad Replacement, SIM Card: passo 3, immagine 2 di 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Keypad Replacement: passo 4, immagine 1 di 3 Motorola i450 Boost Mobile Keypad Replacement: passo 4, immagine 2 di 3 Motorola i450 Boost Mobile Keypad Replacement: passo 4, immagine 3 di 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Keypad Replacement, Circuit Board: passo 5, immagine 1 di 1
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Keypad Replacement: passo 6, immagine 1 di 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Keypad Replacement: passo 7, immagine 1 di 3 Motorola i450 Boost Mobile Keypad Replacement: passo 7, immagine 2 di 3 Motorola i450 Boost Mobile Keypad Replacement: passo 7, immagine 3 di 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  8. Motorola i450 Boost Mobile Keypad Replacement, Keypad: passo 8, immagine 1 di 3 Motorola i450 Boost Mobile Keypad Replacement, Keypad: passo 8, immagine 2 di 3 Motorola i450 Boost Mobile Keypad Replacement, Keypad: passo 8, immagine 3 di 3
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
Conclusione
Garrison Stevens
Membro da: 10/22/12
1 Reputazione
6 Guide realizzate
Clemson, Team 15-2, Benson Fall 2012 Membro di Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 422
