Salta al contenuto principale
Motorola i1000plus Keypad Replacement
Cosa ti serve
  1. Motorola i1000plus Keypad Replacement, Battery: passo 1, immagine 1 di 3 Motorola i1000plus Keypad Replacement, Battery: passo 1, immagine 2 di 3 Motorola i1000plus Keypad Replacement, Battery: passo 1, immagine 3 di 3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Keypad Replacement, Antenna: passo 2, immagine 1 di 3 Motorola i1000plus Keypad Replacement, Antenna: passo 2, immagine 2 di 3 Motorola i1000plus Keypad Replacement, Antenna: passo 2, immagine 3 di 3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Keypad Replacement, Back Cover: passo 3, immagine 1 di 3 Motorola i1000plus Keypad Replacement, Back Cover: passo 3, immagine 2 di 3 Motorola i1000plus Keypad Replacement, Back Cover: passo 3, immagine 3 di 3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Keypad Replacement: passo 4, immagine 1 di 1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Keypad Replacement: passo 5, immagine 1 di 1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Keypad Replacement: passo 6, immagine 1 di 3 Motorola i1000plus Keypad Replacement: passo 6, immagine 2 di 3 Motorola i1000plus Keypad Replacement: passo 6, immagine 3 di 3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
  7. Motorola i1000plus Keypad Replacement, Motherboard: passo 7, immagine 1 di 1
    • Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
  8. Motorola i1000plus Keypad Replacement: passo 8, immagine 1 di 3 Motorola i1000plus Keypad Replacement: passo 8, immagine 2 di 3 Motorola i1000plus Keypad Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone.
    • Do not pull the connector off by the wire. This could damage or destroy the wire or connector.
  9. Motorola i1000plus Keypad Replacement: passo 9, immagine 1 di 2 Motorola i1000plus Keypad Replacement: passo 9, immagine 2 di 2
    • Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board.
    • Do not pull the motherboard too far away from the phone with the ribbon cable still connected. this will damage the cable or the motherboard.
  10. Motorola i1000plus Keypad Replacement: passo 10, immagine 1 di 2 Motorola i1000plus Keypad Replacement: passo 10, immagine 2 di 2
    • Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone.
    • Be sure to pull straight down to disconnect the ribbon cable properly. Pulling in another direction may cause damage to the cable or the motherboard.
  11. Motorola i1000plus Keypad Replacement, Keypad: passo 11, immagine 1 di 3 Motorola i1000plus Keypad Replacement, Keypad: passo 11, immagine 2 di 3 Motorola i1000plus Keypad Replacement, Keypad: passo 11, immagine 3 di 3
    • Using your fingers, carefully lift the rubber keypad from the phone.
    • Note the pegs that stick through the rubber keypad. Lift the keypad carefully so that the pegs do not rip the rubber.
Conclusione
Austin Lake
Membro da: 10/18/13
501 Reputazione
5 Guide realizzate
Clemson, Team 13-3, Benson Fall 2013 Membro di Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Membri
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 277
