Salta al contenuto principale
Motorola Xoom Wifi Motherboard Replacement
Cosa ti serve
  1. Motorola Xoom Wifi Motherboard Replacement, Back Cover Disassembly: passo 1, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement, Back Cover Disassembly: passo 1, immagine 2 di 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Motherboard Replacement: passo 2, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement: passo 2, immagine 2 di 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Motherboard Replacement: passo 3, immagine 1 di 3 Motorola Xoom Wifi Motherboard Replacement: passo 3, immagine 2 di 3 Motorola Xoom Wifi Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Motherboard Replacement, Battery: passo 4, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Motherboard Replacement: passo 5, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement: passo 5, immagine 2 di 2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
  6. Motorola Xoom Wifi Motherboard Replacement, Speakers: passo 6, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement, Speakers: passo 6, immagine 2 di 2
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
  7. Motorola Xoom Wifi Motherboard Replacement, Back-Facing Camera: passo 7, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement, Back-Facing Camera: passo 7, immagine 2 di 2
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  8. Motorola Xoom Wifi Motherboard Replacement: passo 8, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement: passo 8, immagine 2 di 2
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
  9. Motorola Xoom Wifi Motherboard Replacement, Motherboard: passo 9, immagine 1 di 3 Motorola Xoom Wifi Motherboard Replacement, Motherboard: passo 9, immagine 2 di 3 Motorola Xoom Wifi Motherboard Replacement, Motherboard: passo 9, immagine 3 di 3
    • Take a plastic opening tool and carefully pry off the touch screen controller connection.
    • Be careful with the black cover under the connection.
  10. Motorola Xoom Wifi Motherboard Replacement: passo 10, immagine 1 di 3 Motorola Xoom Wifi Motherboard Replacement: passo 10, immagine 2 di 3 Motorola Xoom Wifi Motherboard Replacement: passo 10, immagine 3 di 3
    • There are two relay wires that must be disconnected.
    • Pull both relay wires out of their connection ports.
    • Make sure to flip up the small black tab before you pull out the wire.
  11. Motorola Xoom Wifi Motherboard Replacement: passo 11, immagine 1 di 2 Motorola Xoom Wifi Motherboard Replacement: passo 11, immagine 2 di 2
    • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
  12. Motorola Xoom Wifi Motherboard Replacement: passo 12, immagine 1 di 3 Motorola Xoom Wifi Motherboard Replacement: passo 12, immagine 2 di 3 Motorola Xoom Wifi Motherboard Replacement: passo 12, immagine 3 di 3
    • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
    • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
    • Motherboard should lift out easily and completely.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 3-39, Maness Spring 2014 Membro di Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Membri
16 Guide realizzate
Un commento
Is the hdmi port replaceable or part of the motherboard?
uvawalls - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,161
