Salta al contenuto principale
Motorola Xoom Wifi Earphone Port Replacement
Cosa ti serve
  1. Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: passo 1, immagine 1 di 2 Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: passo 1, immagine 2 di 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola Xoom Wifi Earphone Port Replacement: passo 2, immagine 1 di 2 Motorola Xoom Wifi Earphone Port Replacement: passo 2, immagine 2 di 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola Xoom Wifi Earphone Port Replacement: passo 3, immagine 1 di 3 Motorola Xoom Wifi Earphone Port Replacement: passo 3, immagine 2 di 3 Motorola Xoom Wifi Earphone Port Replacement: passo 3, immagine 3 di 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: passo 4, immagine 1 di 3 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: passo 4, immagine 2 di 3 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: passo 4, immagine 3 di 3
    • Remove one screw with a T-5 bit.
    • Lift the black casing off of the ports.
    • Remove earphone port from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 3-39, Maness Spring 2014 Membro di Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 38
Tutti i Tempi: 527
