Introduzione
Common problems with the Xoom 2 is a gradually forming looseness in the charging port assembly or even a bent or broken charging port. Follow this guide to replace or fix your charging port assembly.
Note: We will be using a Torx T5 screwdriver for all of the steps in this guide.
Cosa ti serve
Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
Using tweezers, gently pry up the piece of yellow Kapton tape that is holding several cables in place.
