Salta al contenuto principale
Motorola XOOM 2 Media Edition Touch Screen Replacement
Cosa ti serve
  1. Motorola XOOM 2 Media Edition Touch Screen Replacement, Motorola XOOM 2 Media Edition Disassembly: passo 1, immagine 1 di 2 Motorola XOOM 2 Media Edition Touch Screen Replacement, Motorola XOOM 2 Media Edition Disassembly: passo 1, immagine 2 di 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 2, immagine 1 di 2 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 2, immagine 2 di 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 3, immagine 1 di 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 3, immagine 2 di 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 3, immagine 3 di 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Touch Screen Replacement, Touch Screen: passo 4, immagine 1 di 2 Motorola XOOM 2 Media Edition Touch Screen Replacement, Touch Screen: passo 4, immagine 2 di 2
    • Remove thirteen 2.55mm Torx #4 screws with Torx T4 screwdriver.
  5. Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to pull up the white rubber cover.
  6. Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 6, immagine 1 di 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 6, immagine 2 di 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 6, immagine 3 di 3
    • Use the tweezers to pull up the small chip from its receiver.
    • Use the tweezers to pull up the larger chip from its receiver.
    • There is adhesive attached to the back of the larger chip on the touchscreen controller strip.
    • Use the tweezers to pull up one end of the small piece of tape that is holding the touchscreen controller.
  7. Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 7, immagine 1 di 2 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 7, immagine 2 di 2
    • Use the tweezers to pull up and release the thin handle that is attached to the LCD connector.
    • Use the tweezers to pull out the LCD connector from its receptor.
  8. Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 8, immagine 1 di 2 Motorola XOOM 2 Media Edition Touch Screen Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to gradually separate the screen from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 645
