Salta al contenuto principale
Motorola XOOM 2 Media Edition Microphone Replacement
Cosa ti serve
  1. Motorola XOOM 2 Media Edition Microphone Replacement, Motorola XOOM 2 Media Edition Disassembly: passo 1, immagine 1 di 2 Motorola XOOM 2 Media Edition Microphone Replacement, Motorola XOOM 2 Media Edition Disassembly: passo 1, immagine 2 di 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Microphone Replacement: passo 2, immagine 1 di 2 Motorola XOOM 2 Media Edition Microphone Replacement: passo 2, immagine 2 di 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Microphone Replacement: passo 3, immagine 1 di 3 Motorola XOOM 2 Media Edition Microphone Replacement: passo 3, immagine 2 di 3 Motorola XOOM 2 Media Edition Microphone Replacement: passo 3, immagine 3 di 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Microphone Replacement, Microphone: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently pull up rubber housing with tweezers from above microphone.
    • There is adhesive holding down the rubber microphone housing.
  5. Motorola XOOM 2 Media Edition Microphone Replacement: passo 5, immagine 1 di 1
    • Using the tweezers, gently pull up the connector off the microphone.
  6. Motorola XOOM 2 Media Edition Microphone Replacement: passo 6, immagine 1 di 2 Motorola XOOM 2 Media Edition Microphone Replacement: passo 6, immagine 2 di 2
    • Once the connector is removed, use the tweezers to pull up the microphone from its plastic socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 166
