Salta al contenuto principale
Motorola XOOM 2 Media Edition Battery Replacement
Cosa ti serve
  1. Motorola XOOM 2 Media Edition Battery Replacement, Battery: passo 1, immagine 1 di 2 Motorola XOOM 2 Media Edition Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Power off your tablet before beginning disassembly.
    • Remove six 2.74mm Torx #3 screws from the back panel of the device with a Torx T3 screwdriver.
  2. Motorola XOOM 2 Media Edition Battery Replacement: passo 2, immagine 1 di 2 Motorola XOOM 2 Media Edition Battery Replacement: passo 2, immagine 2 di 2
    • There is adhesive attached to the underside of the back panel. Gradually lift panel to avoid bending it out of shape.
    • Pry off the back panel with a plastic opening tool.
  3. Motorola XOOM 2 Media Edition Battery Replacement: passo 3, immagine 1 di 2 Motorola XOOM 2 Media Edition Battery Replacement: passo 3, immagine 2 di 2
    • These screws are tight and prone to becoming stripped.
    • The battery cables are likely to snap when removing the screws.
    • Remove two 2.38mm Torx #5 screws from battery cables with Torx T5 screwdriver.
  4. Motorola XOOM 2 Media Edition Battery Replacement: passo 4, immagine 1 di 3 Motorola XOOM 2 Media Edition Battery Replacement: passo 4, immagine 2 di 3 Motorola XOOM 2 Media Edition Battery Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull up the battery cables and battery chip with tweezers.
  5. Motorola XOOM 2 Media Edition Battery Replacement: passo 5, immagine 1 di 2 Motorola XOOM 2 Media Edition Battery Replacement: passo 5, immagine 2 di 2
    • Pry the battery out of the device with the plastic opening tool.
    • Some force is needed to lift the battery up because of the adhesive attached to the backside of the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,060
