Salta al contenuto principale
Motorola W490 Circuit Board Replacement
Cosa ti serve
  1. Motorola W490 Circuit Board Replacement, Phone Casing: passo 1, immagine 1 di 2 Motorola W490 Circuit Board Replacement, Phone Casing: passo 1, immagine 2 di 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 Circuit Board Replacement, Battery: passo 2, immagine 1 di 2 Motorola W490 Circuit Board Replacement, Battery: passo 2, immagine 2 di 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 Circuit Board Replacement, Lower Metal Frame: passo 3, immagine 1 di 2 Motorola W490 Circuit Board Replacement, Lower Metal Frame: passo 3, immagine 2 di 2
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
  4. Motorola W490 Circuit Board Replacement: passo 4, immagine 1 di 3 Motorola W490 Circuit Board Replacement: passo 4, immagine 2 di 3 Motorola W490 Circuit Board Replacement: passo 4, immagine 3 di 3
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
  5. Motorola W490 Circuit Board Replacement: passo 5, immagine 1 di 2 Motorola W490 Circuit Board Replacement: passo 5, immagine 2 di 2
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
  6. Motorola W490 Circuit Board Replacement: passo 6, immagine 1 di 3 Motorola W490 Circuit Board Replacement: passo 6, immagine 2 di 3 Motorola W490 Circuit Board Replacement: passo 6, immagine 3 di 3
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
  7. Motorola W490 Circuit Board Replacement, Circuit Board: passo 7, immagine 1 di 3 Motorola W490 Circuit Board Replacement, Circuit Board: passo 7, immagine 2 di 3 Motorola W490 Circuit Board Replacement, Circuit Board: passo 7, immagine 3 di 3
    • Identify the flex cable attachment. Indicated in a red square.
    • Detach the bottom half of the flex cable, pop it off of the circuit board.
    • Pick up the loosened circuit board from the phone and set aside.
Conclusione
Altre 2 persone hanno completato questa guida.
Eric Kim
Membro da: 10/22/12
52 Reputazione
1 Guida realizzata
Clemson, Team 14-1, Benson Fall 2012 Membro di Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membri
23 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 665
