Salta al contenuto principale
Motorola W385 speaker replacement
Cosa ti serve
  1. Motorola W385 speaker replacement, Battery: passo 1, immagine 1 di 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 speaker replacement: passo 2, immagine 1 di 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 speaker replacement, Front Casing: passo 3, immagine 1 di 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 speaker replacement: passo 4, immagine 1 di 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 speaker replacement: passo 5, immagine 1 di 2 Motorola W385 speaker replacement: passo 5, immagine 2 di 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 speaker replacement: passo 6, immagine 1 di 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 speaker replacement, Top Logic Board: passo 7, immagine 1 di 1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 speaker replacement: passo 8, immagine 1 di 3 Motorola W385 speaker replacement: passo 8, immagine 2 di 3 Motorola W385 speaker replacement: passo 8, immagine 3 di 3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 speaker replacement: passo 9, immagine 1 di 3 Motorola W385 speaker replacement: passo 9, immagine 2 di 3 Motorola W385 speaker replacement: passo 9, immagine 3 di 3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
  10. Motorola W385 speaker replacement, Main Speaker: passo 10, immagine 1 di 1
    • Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
  11. Motorola W385 speaker replacement: passo 11, immagine 1 di 2 Motorola W385 speaker replacement: passo 11, immagine 2 di 2
    • Place the spudger between the speaker and the clip shown.
    • Separate the clip from the speaker while lifting on the speaker.
    • The speaker should separate. Use the tweezers to grab the speaker.
Conclusione
Koedy Brant
Membro da: 01/26/10
41 Reputazione
2 Guide realizzate
Cal Poly, Team 8-50, Regan Winter 2010 Membro di Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,153
