Salta al contenuto principale
Motorola W315 Rear Case Replacement
Cosa ti serve
  1. Motorola W315 Rear Case Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Rear Case Replacement: passo 3, immagine 1 di 1
    • Insert the new battery.
  3. Motorola W315 Rear Case Replacement, Rear Case: passo 4, immagine 1 di 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Rear Case Replacement: passo 5, immagine 1 di 3 Motorola W315 Rear Case Replacement: passo 5, immagine 2 di 3 Motorola W315 Rear Case Replacement: passo 5, immagine 3 di 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
Conclusione
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
Membro da: 03/26/14
501 Reputazione
5 Guide realizzate
Clemson, Team 6-3, Benson Spring 2014 Membro di Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 205
