Cosa ti serve
Four 5 mm screws are visible (circled in red).
Using the T6 tool, remove all four 5mm screws and set them aside.
Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
Apply pressure to the side buttons to remove them from the frame.
Turn the device over and push the keypad to loosen it from the frame.
Turn the device over again and gently pull the keypad away from the frame.
Warning: Keypad may not respond due to unclean button contacts, make sure the button contacts remain clean throughout the disassembly and reassembly of the phone.
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
