Salta al contenuto principale
Motorola V60s Speakers Replacement
Cosa ti serve
  1. Motorola V60s Speakers Replacement, Battery: passo 1, immagine 1 di 3 Motorola V60s Speakers Replacement, Battery: passo 1, immagine 2 di 3 Motorola V60s Speakers Replacement, Battery: passo 1, immagine 3 di 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: passo 2, immagine 1 di 2 Motorola V60s Speakers Replacement: passo 2, immagine 2 di 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: passo 3, immagine 1 di 2 Motorola V60s Speakers Replacement, Speakers: passo 3, immagine 2 di 2
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: passo 4, immagine 1 di 2 Motorola V60s Speakers Replacement: passo 4, immagine 2 di 2
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: passo 5, immagine 1 di 1
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
Conclusione
Eric Freeman
Membro da: 01/26/10
10 Reputazione
7 Guide realizzate
Cal Poly, Team 8-48, Regan Winter 2010 Membro di Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,571
