Salta al contenuto principale
Motorola V60s Battery Replacement
Cosa ti serve
  1. Motorola V60s Battery Replacement, Battery: passo 1, immagine 1 di 3 Motorola V60s Battery Replacement, Battery: passo 1, immagine 2 di 3 Motorola V60s Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Battery Replacement: passo 2, immagine 1 di 2 Motorola V60s Battery Replacement: passo 2, immagine 2 di 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
Conclusione
Cal Poly, Team 8-48, Regan Winter 2010 Membro di Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,730
