Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
How to replace the logic board.
  1. Depress the silver button. Pull from top of phone to lift the cover.
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Hold battery from both sides at the bottom. Push upwards and gently lift to remove.
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove 4 screws from corners using T-6 screwdriver.
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  5. Use a plastic opening tool to pry up back cover from the two side clips. NOTE: sticker might be attached to rest of phone.
    • Use a plastic opening tool to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
  6. Remove the back cover.
    • Remove the back cover.
  7. Use a plastic opening tool to gently remove the orange ribbon cable. Lift up the main logic board to remove.
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board to remove.
Conclusione
Ryan Kuroiwa
Membro da: 10/04/2010
1 Reputazione
5 Guide realizzate
Cal Poly, Team 25-86, Amido Spring 2010 Membro di Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,257
