Salta al contenuto principale
Motorola V60c Keypad and Keypad Logic Board Replacement
Ryan Kuroiwa
Ryan Kuroiwa e 6 altri collaboratori
Ultimo aggiornamento il December 19, 2017
10 - 15 minuti
Facile
Prerequisite Mancanti
Introduzione
Vai al passo 1
How to replace the keypad and keypad logic board.
Cosa ti serve
Strumenti
Mostra di più…
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: passo 1, immagine 1 di 2 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: passo 1, immagine 2 di 2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 2, immagine 1 di 2 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 2, immagine 2 di 2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: passo 3, immagine 1 di 1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 4, immagine 1 di 2 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 4, immagine 2 di 2
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 5, immagine 1 di 1
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 6, immagine 1 di 2 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 6, immagine 2 di 2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 7, immagine 1 di 2 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 7, immagine 2 di 2
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: passo 8, immagine 1 di 3 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 8, immagine 2 di 3 Motorola V60c Keypad and Keypad Logic Board Replacement: passo 8, immagine 3 di 3
    • Remove the keypad.
Conclusione
Cal Poly, Team 25-86, Amido Spring 2010 Membro di Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,167
