Salta al contenuto principale
Motorola V557 Rear Casing Replacement
Cosa ti serve
  1. Motorola V557 Rear Casing Replacement, Battery: passo 1, immagine 1 di 3 Motorola V557 Rear Casing Replacement, Battery: passo 1, immagine 2 di 3 Motorola V557 Rear Casing Replacement, Battery: passo 1, immagine 3 di 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Rear Casing Replacement: passo 2, immagine 1 di 2 Motorola V557 Rear Casing Replacement: passo 2, immagine 2 di 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Rear Casing Replacement, SIM Card: passo 3, immagine 1 di 3 Motorola V557 Rear Casing Replacement, SIM Card: passo 3, immagine 2 di 3 Motorola V557 Rear Casing Replacement, SIM Card: passo 3, immagine 3 di 3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Rear Casing Replacement, Antenna: passo 4, immagine 1 di 2 Motorola V557 Rear Casing Replacement, Antenna: passo 4, immagine 2 di 2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Rear Casing Replacement, Rear Casing: passo 5, immagine 1 di 3 Motorola V557 Rear Casing Replacement, Rear Casing: passo 5, immagine 2 di 3 Motorola V557 Rear Casing Replacement, Rear Casing: passo 5, immagine 3 di 3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Rear Casing Replacement: passo 6, immagine 1 di 3 Motorola V557 Rear Casing Replacement: passo 6, immagine 2 di 3 Motorola V557 Rear Casing Replacement: passo 6, immagine 3 di 3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Rear Casing Replacement: passo 7, immagine 1 di 3 Motorola V557 Rear Casing Replacement: passo 7, immagine 2 di 3 Motorola V557 Rear Casing Replacement: passo 7, immagine 3 di 3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
Conclusione
Cal Poly, Team 7-50, Amido Fall 2010 Membro di Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,360
