Salta al contenuto principale
Motorola V276 Speaker Replacement
Cosa ti serve
  1. Motorola V276 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Speaker Replacement: passo 2, immagine 1 di 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Speaker Replacement: passo 3, immagine 1 di 2 Motorola V276 Speaker Replacement: passo 3, immagine 2 di 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  5. Motorola V276 Speaker Replacement: passo 5, immagine 1 di 1
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  6. Motorola V276 Speaker Replacement: passo 6, immagine 1 di 3 Motorola V276 Speaker Replacement: passo 6, immagine 2 di 3 Motorola V276 Speaker Replacement: passo 6, immagine 3 di 3
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Speaker Replacement: passo 7, immagine 1 di 2 Motorola V276 Speaker Replacement: passo 7, immagine 2 di 2
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  8. Motorola V276 Speaker Replacement: passo 8, immagine 1 di 2 Motorola V276 Speaker Replacement: passo 8, immagine 2 di 2
    • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
  9. Motorola V276 Speaker Replacement: passo 9, immagine 1 di 1
    • Using a spudger, remove the speaker
Conclusione
Cal Poly, Team 27-96, Amido Spring 2010 Membro di Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,005
