Salta al contenuto principale
Motorola V276 Small LCD Display Screen Replacement
Cosa ti serve
  1. Motorola V276 Small LCD Display Screen Replacement, Front panel/ Screen Logic Board: passo 1, immagine 1 di 1
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Motorola V276 Small LCD Display Screen Replacement: passo 2, immagine 1 di 1
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Motorola V276 Small LCD Display Screen Replacement: passo 3, immagine 1 di 1
    • Remove silver plate from phone.
  4. Motorola V276 Small LCD Display Screen Replacement: passo 4, immagine 1 di 1
    • Using the spudger remove the plastic camera casing
  5. Motorola V276 Small LCD Display Screen Replacement: passo 5, immagine 1 di 1
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Motorola V276 Small LCD Display Screen Replacement: passo 6, immagine 1 di 1
    • Use Spudger or hands to detach flex cable from front screen logic board
  7. Motorola V276 Small LCD Display Screen Replacement, Small LCD Display Screen: passo 7, immagine 1 di 1
    • Use a plastic opening tool to lift the small black flap to unlock the screen from the motherboard.
  8. Motorola V276 Small LCD Display Screen Replacement: passo 8, immagine 1 di 1
    • Using your fingers, carefully pull out the small LCD display screen.
  9. Motorola V276 Small LCD Display Screen Replacement: passo 9, immagine 1 di 1
    • Remove the small LCD display screen completely from the green logic board.
Conclusione
Cecilia
Membro da: 04/11/10
1 Reputazione
3 Guide realizzate
Cal Poly, Team 27-96, Amido Spring 2010 Membro di Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,733
