Salta al contenuto principale
Motorola V276 Battery Replacement
Cosa ti serve
  1. Motorola V276 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Battery Replacement: passo 2, immagine 1 di 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Battery Replacement: passo 3, immagine 1 di 2 Motorola V276 Battery Replacement: passo 3, immagine 2 di 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Conclusione
Cal Poly, Team 27-96, Amido Spring 2010 Membro di Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,674
