Salta al contenuto principale
Motorola V2397 Motherboard/Screen Replacement
Cosa ti serve
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: passo 1, immagine 1 di 3 Motorola V2397 Motherboard/Screen Replacement, Battery: passo 1, immagine 2 di 3 Motorola V2397 Motherboard/Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: passo 2, immagine 1 di 2 Motorola V2397 Motherboard/Screen Replacement: passo 2, immagine 2 di 2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: passo 3, immagine 1 di 2 Motorola V2397 Motherboard/Screen Replacement, Back Cover: passo 3, immagine 2 di 2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: passo 4, immagine 1 di 2 Motorola V2397 Motherboard/Screen Replacement: passo 4, immagine 2 di 2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: passo 5, immagine 1 di 2 Motorola V2397 Motherboard/Screen Replacement, Phone: passo 5, immagine 2 di 2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: passo 6, immagine 1 di 2 Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: passo 6, immagine 2 di 2
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: passo 7, immagine 1 di 2 Motorola V2397 Motherboard/Screen Replacement: passo 7, immagine 2 di 2
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
Conclusione
Chris
Membro da: 01/13/15
501 Reputazione
5 Guide realizzate
USF Tampa, Team 1-6, Sullivan Winter 2015 Membro di USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 159
