Salta al contenuto principale
Motorola V2397 Front Cover Replacement
Cosa ti serve
  1. Motorola V2397 Front Cover Replacement, Battery: passo 1, immagine 1 di 3 Motorola V2397 Front Cover Replacement, Battery: passo 1, immagine 2 di 3 Motorola V2397 Front Cover Replacement, Battery: passo 1, immagine 3 di 3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Front Cover Replacement: passo 2, immagine 1 di 2 Motorola V2397 Front Cover Replacement: passo 2, immagine 2 di 2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Front Cover Replacement, Back Cover: passo 3, immagine 1 di 2 Motorola V2397 Front Cover Replacement, Back Cover: passo 3, immagine 2 di 2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Front Cover Replacement: passo 4, immagine 1 di 2 Motorola V2397 Front Cover Replacement: passo 4, immagine 2 di 2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Front Cover Replacement, Side Buttons: passo 5, immagine 1 di 2 Motorola V2397 Front Cover Replacement, Side Buttons: passo 5, immagine 2 di 2
    • Lift and remove buttons by hand
  6. Motorola V2397 Front Cover Replacement, Phone: passo 6, immagine 1 di 2 Motorola V2397 Front Cover Replacement, Phone: passo 6, immagine 2 di 2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  7. Motorola V2397 Front Cover Replacement, Keypad: passo 7, immagine 1 di 3 Motorola V2397 Front Cover Replacement, Keypad: passo 7, immagine 2 di 3 Motorola V2397 Front Cover Replacement, Keypad: passo 7, immagine 3 di 3
    • Grip the top of the rubber keypad with your thumb and index finger
    • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
  8. Motorola V2397 Front Cover Replacement, Speaker: passo 8, immagine 1 di 2 Motorola V2397 Front Cover Replacement, Speaker: passo 8, immagine 2 di 2
    • Use the iFixit opening tool to lift the speaker off the front cover.
  9. Motorola V2397 Front Cover Replacement, Front Cover: passo 9, immagine 1 di 2 Motorola V2397 Front Cover Replacement, Front Cover: passo 9, immagine 2 di 2
    • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
Conclusione
Connor
Membro da: 01/13/15
201 Reputazione
2 Guide realizzate
USF Tampa, Team 1-6, Sullivan Winter 2015 Membro di USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 185
