Salta al contenuto principale
Motorola V190 Mini-USB Port/Motherboard Replacement
Cosa ti serve
  1. Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: passo 1, immagine 1 di 2 Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: passo 1, immagine 2 di 2
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
  2. Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: passo 2, immagine 1 di 2 Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: passo 2, immagine 2 di 2
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
  3. Motorola V190 Mini-USB Port/Motherboard Replacement, Mini-USB Port/Motherboard: passo 3, immagine 1 di 1
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
  4. Motorola V190 Mini-USB Port/Motherboard Replacement: passo 4, immagine 1 di 3 Motorola V190 Mini-USB Port/Motherboard Replacement: passo 4, immagine 2 di 3 Motorola V190 Mini-USB Port/Motherboard Replacement: passo 4, immagine 3 di 3
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
  5. Motorola V190 Mini-USB Port/Motherboard Replacement: passo 5, immagine 1 di 3 Motorola V190 Mini-USB Port/Motherboard Replacement: passo 5, immagine 2 di 3 Motorola V190 Mini-USB Port/Motherboard Replacement: passo 5, immagine 3 di 3
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 180
