Salta al contenuto principale
Motorola V180 Motherboard Replacement
Cosa ti serve
  1. Motorola V180 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Motorola V180 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Motorola V180 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: passo 2, immagine 1 di 3 Motorola V180 Motherboard Replacement, Motherboard: passo 2, immagine 2 di 3 Motorola V180 Motherboard Replacement, Motherboard: passo 2, immagine 3 di 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: passo 3, immagine 1 di 2 Motorola V180 Motherboard Replacement: passo 3, immagine 2 di 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Conclusione
Cal Poly, Team 6-16, Maness Spring 2010 Membro di Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,579
