Salta al contenuto principale
Motorola T720c Battery Replacement
  1. Motorola T720c Battery Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the phone, locate the tab with the down arrow.
    • Using your finger, press the tab and slide the back cover down to release it from the phone.
  2. Motorola T720c Battery Replacement: passo 2, immagine 1 di 1
    • Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
  3. Motorola T720c Battery Replacement, Battery: passo 3, immagine 1 di 2 Motorola T720c Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Locate the stepped indentations on the front of the battery.
    • With the front of the battery facing outward, insert the bottom edge into the battery housing and press battery into the phone .
    • Replace the back cover (not shown).
Conclusione
Kristina King
Membro da: 10/15/12
1 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 374
