Salta al contenuto principale
Motorola Slvr L7 Camera Assembly Replacement
Cosa ti serve
  1. Motorola Slvr L7 Camera Assembly Replacement, Camera Assembly: passo 1, immagine 1 di 1
    • To ensure safety, discharge your phone battery below 25% before starting. A fully charged lithium-ion battery may cause a fire and/or explosion due to defects or damage.
    • Turn off your phone before beginning disassembly.
    • To replace the camera, first begin by removing the battery.
    • Push down on the black tab at the Motorola phone’s top center to detach the back phone cover and access the battery.
  2. Motorola Slvr L7 Camera Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the battery on the back of the Motorola phone by pulling it away from the back of the phone.
  3. Motorola Slvr L7 Camera Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the four (4) T6 Torx screws from the back of the metal back plate.
  4. Motorola Slvr L7 Camera Assembly Replacement: passo 4, immagine 1 di 2 Motorola Slvr L7 Camera Assembly Replacement: passo 4, immagine 2 di 2
    • Remove the metal cover by inserting the flat end of the iFixit Opening Tool under the side of the cover, prying it away from the phone.
  5. Motorola Slvr L7 Camera Assembly Replacement: passo 5, immagine 1 di 2 Motorola Slvr L7 Camera Assembly Replacement: passo 5, immagine 2 di 2
    • Carefully separate the two connectors from their sockets on the motherboard using the flat end of the iFixit Opening Tool, so the two connectors are open.
  6. Motorola Slvr L7 Camera Assembly Replacement: passo 6, immagine 1 di 2 Motorola Slvr L7 Camera Assembly Replacement: passo 6, immagine 2 di 2
    • Use the flat end iFixit Opening Tool to pry the antenna cable connectors from their respective sockets on the motherboard.
    • Pull the antenna cable out to de-route it from the phone.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,023
