Salta al contenuto principale
Motorola SURFboard SB5101 Face Plate Replacement
Cosa ti serve
  1. Motorola SURFboard SB5101 Face Plate Replacement, Removing the Screw on the Back of the Device: passo 1, immagine 1 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Screw on the Back of the Device: passo 1, immagine 2 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Screw on the Back of the Device: passo 1, immagine 3 di 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Face Plate Replacement, Unlocking Router: passo 2, immagine 1 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Unlocking Router: passo 2, immagine 2 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Unlocking Router: passo 2, immagine 3 di 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Face Plate Replacement, Removing the Cover: passo 3, immagine 1 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Cover: passo 3, immagine 2 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Cover: passo 3, immagine 3 di 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Face Plate Replacement, Grabbing the Motherboard: passo 4, immagine 1 di 2 Motorola SURFboard SB5101 Face Plate Replacement, Grabbing the Motherboard: passo 4, immagine 2 di 2
    • After opening the router, grab the upper left corner of the sliver face plate and gently pull the motherboard out of the slot from within the case.
  5. Motorola SURFboard SB5101 Face Plate Replacement, Removing the Motherboard: passo 5, immagine 1 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Motherboard: passo 5, immagine 2 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Motherboard: passo 5, immagine 3 di 3
    • Slowly lift the motherboard out of the case.
  6. Motorola SURFboard SB5101 Face Plate Replacement, Unscrew the Silver Antennae Jack Screw: passo 6, immagine 1 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Unscrew the Silver Antennae Jack Screw: passo 6, immagine 2 di 3 Motorola SURFboard SB5101 Face Plate Replacement, Unscrew the Silver Antennae Jack Screw: passo 6, immagine 3 di 3
    • Begin by grabbing the washer on the silver antennae jack screw.
    • Start unscrewing the washer by turning it counterclockwise.
    • Continue to unscrew the washer until it comes off the screw.
    • If you cannot unscrew the washer with your finger, you may need to use a small wrench to grab the washer.
    • Set the washer aside.
  7. Motorola SURFboard SB5101 Face Plate Replacement, Removing the Face Plate: passo 7, immagine 1 di 2 Motorola SURFboard SB5101 Face Plate Replacement, Removing the Face Plate: passo 7, immagine 2 di 2
    • Grab both corner ends of the silver face plate.
    • Gently pull the face plate away from the router, gently wiggling it off the screw.
Conclusione
Follow these directions in reverse order to replace a new face plate, or put the same faceplate back in place after you have finished working on the electrical components underneath.
Altre 2 persone hanno completato questa guida.
Cayce Rast
Membro da: 10/13/14
421 Reputazione
3 Guide realizzate
Clemson, Team 1-2, Benson Fall 2014 Membro di Clemson, Team 1-2, Benson Fall 2014
CLEM-BENSON-F14S1G2
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,165
