Salta al contenuto principale
Motorola SLVR L9 Front Panel Replacement
Cosa ti serve
  1. Motorola SLVR L9 Front Panel Replacement, Battery: passo 1, immagine 1 di 2 Motorola SLVR L9 Front Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Front Panel Replacement: passo 2, immagine 1 di 3 Motorola SLVR L9 Front Panel Replacement: passo 2, immagine 2 di 3 Motorola SLVR L9 Front Panel Replacement: passo 2, immagine 3 di 3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Front Panel Replacement: passo 3, immagine 1 di 3 Motorola SLVR L9 Front Panel Replacement: passo 3, immagine 2 di 3 Motorola SLVR L9 Front Panel Replacement: passo 3, immagine 3 di 3
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: passo 4, immagine 1 di 2 Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: passo 4, immagine 2 di 2
    • Turn the phone over so that the back of the phone is facing towards you.
  5. Motorola SLVR L9 Front Panel Replacement: passo 5, immagine 1 di 3 Motorola SLVR L9 Front Panel Replacement: passo 5, immagine 2 di 3 Motorola SLVR L9 Front Panel Replacement: passo 5, immagine 3 di 3
    • Press down on the battery cover latch located at the top of the phone.
  6. Motorola SLVR L9 Front Panel Replacement: passo 6, immagine 1 di 1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  7. Motorola SLVR L9 Front Panel Replacement: passo 7, immagine 1 di 2 Motorola SLVR L9 Front Panel Replacement: passo 7, immagine 2 di 2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
  8. Motorola SLVR L9 Front Panel Replacement, Antenna Cover: passo 8, immagine 1 di 3 Motorola SLVR L9 Front Panel Replacement, Antenna Cover: passo 8, immagine 2 di 3 Motorola SLVR L9 Front Panel Replacement, Antenna Cover: passo 8, immagine 3 di 3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
  9. Motorola SLVR L9 Front Panel Replacement, Front Panel: passo 9, immagine 1 di 1
    • Use a screwdriver with a T6 Torx screwdriver head to turn the screw counter-clockwise (left).
  10. Motorola SLVR L9 Front Panel Replacement: passo 10, immagine 1 di 3 Motorola SLVR L9 Front Panel Replacement: passo 10, immagine 2 di 3 Motorola SLVR L9 Front Panel Replacement: passo 10, immagine 3 di 3
    • Using the grooves around the edge of the phone, gently pull the front panel away from the phone until it is fully removed from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 157
