Salta al contenuto principale
Motorola SLVR L9 Camera Lens Cover Replacement
Cosa ti serve
  1. Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: passo 1, immagine 1 di 2 Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: passo 1, immagine 2 di 2
    • Turn the phone over so that the back of the phone is facing towards you.
  2. Motorola SLVR L9 Camera Lens Cover Replacement: passo 2, immagine 1 di 3 Motorola SLVR L9 Camera Lens Cover Replacement: passo 2, immagine 2 di 3 Motorola SLVR L9 Camera Lens Cover Replacement: passo 2, immagine 3 di 3
    • Press down on the battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Camera Lens Cover Replacement: passo 3, immagine 1 di 1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  4. Motorola SLVR L9 Camera Lens Cover Replacement: passo 4, immagine 1 di 2 Motorola SLVR L9 Camera Lens Cover Replacement: passo 4, immagine 2 di 2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 181
