Salta al contenuto principale
Motorola Rival Keyboard Replacement
Cosa ti serve
  1. Motorola Rival Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Motorola Rival Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Motorola Rival Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Push down on the release tab and pull the back cover away from the device, exposing the battery.
  2. Motorola Rival Keyboard Replacement: passo 2, immagine 1 di 2 Motorola Rival Keyboard Replacement: passo 2, immagine 2 di 2
    • Lift the battery from its compartment to remove it.
  3. Motorola Rival Keyboard Replacement: passo 3, immagine 1 di 2 Motorola Rival Keyboard Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six screws around the edge of the device.
  4. Motorola Rival Keyboard Replacement: passo 4, immagine 1 di 2 Motorola Rival Keyboard Replacement: passo 4, immagine 2 di 2
    • Insert the iFixit Opening Tool into the seam where the front and back panels meet and work your way around the perimeter to separate the two panels.
    • Once the two panels are separated, set the front panel to the side. You will be working with the back panel to access the keyboard.
    • The motherboard is now exposed on the back panel.
  5. Motorola Rival Keyboard Replacement: passo 5, immagine 1 di 1
    • Use the iFixit Opening Tool to lift the camera button and remove it from its position.
  6. Motorola Rival Keyboard Replacement: passo 6, immagine 1 di 1
    • Use the iFixit Opening Tool to lift the lock/mute button and remove it from its position.
  7. Motorola Rival Keyboard Replacement: passo 7, immagine 1 di 1
    • Use the iFixit Opening Tool to lift the volume buttons and remove them from their position.
  8. Motorola Rival Keyboard Replacement: passo 8, immagine 1 di 2 Motorola Rival Keyboard Replacement: passo 8, immagine 2 di 2
    • Slide the keyboard out.
    • Use a Phillips #00 screwdriver to remove all of the screws.
  9. Motorola Rival Keyboard Replacement: passo 9, immagine 1 di 3 Motorola Rival Keyboard Replacement: passo 9, immagine 2 di 3 Motorola Rival Keyboard Replacement: passo 9, immagine 3 di 3
    • Insert the iFixit Opening Tool under the edges of the motherboard to lift it out of the back panel and expose the keyboard.
  10. Motorola Rival Keyboard Replacement: passo 10, immagine 1 di 1
    • Remove the old keyboard from the frame.
    • Place the new keyboard into the frame and align the buttons into their respective openings.
Conclusione
To reassemble your device, follow these steps in reverse order.
Sekani Paul
Membro da: 11/04/15
231 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 1-8, Bhusal Fall 2015 Membro di UMass Dartmouth, Team 1-8, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G8
2 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 317
