Salta al contenuto principale
Motorola Razr V3m Screen/Camera Replacement
Cosa ti serve
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: passo 1, immagine 1 di 2 Motorola Razr V3m Screen/Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Screen/Camera Replacement: passo 2, immagine 1 di 2 Motorola Razr V3m Screen/Camera Replacement: passo 2, immagine 2 di 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: passo 3, immagine 1 di 2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: passo 3, immagine 2 di 2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
  4. Motorola Razr V3m Screen/Camera Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
  5. Motorola Razr V3m Screen/Camera Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the two side buttons with tweezers.
  6. Motorola Razr V3m Screen/Camera Replacement: passo 6, immagine 1 di 1
    • Use tweezers to remove the circular magnetic ring covering the camera.
  7. Motorola Razr V3m Screen/Camera Replacement: passo 7, immagine 1 di 2 Motorola Razr V3m Screen/Camera Replacement: passo 7, immagine 2 di 2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
Conclusione
UMass Dartmouth, Team 3-2, Shastany Fall 2015 Membro di UMass Dartmouth, Team 3-2, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G2
4 Membri
7 Guide realizzate
Un commento
where can this part be purchased?
Alex Alexander - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 430
