Salta al contenuto principale
Motorola Razr V3c Upper Casing (CDMA) Replacement
Cosa ti serve
  1. Motorola Razr V3c Upper Casing (CDMA) Replacement, Upper Casing (CDMA): passo 1, immagine 1 di 1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Upper Casing (CDMA) Replacement: passo 2, immagine 1 di 1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Upper Casing (CDMA) Replacement: passo 3, immagine 1 di 1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Upper Casing (CDMA) Replacement: passo 4, immagine 1 di 3 Motorola Razr V3c Upper Casing (CDMA) Replacement: passo 4, immagine 2 di 3 Motorola Razr V3c Upper Casing (CDMA) Replacement: passo 4, immagine 3 di 3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Conclusione
Altre 4 persone hanno completato questa guida.
krisko
Membro da: 01/14/10
104 Reputazione
4 Guide realizzate
Cal Poly, Team 11-4, Forte Winter 2010 Membro di Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,338
