Introduzione
This guide will show you how to remove and replace the screen for a Motorola V3c.
Parti
Nessuna parte richiesta.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Aggiungi Commento
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
Aggiungi Commento
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Aggiungi Commento
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Aggiungi Commento
  • Pry screen cover off with plastic spudger.
  • The screen cover has some adhesive holding it to the screen
Aggiungi Commento
  • Remove small black sticker covering the camera ribbon connector.
Aggiungi Commento
  • Flip over small hinge that covers the camera ribbon connection.
Aggiungi Commento
  • Pull off the rubber camera cover and camera.
  • The camera and camera cover may come off either separately or together.
Aggiungi Commento
  • Disconnect the metallic ribbon cover.
Aggiungi Commento
  • Remove and replace the screen.
Aggiungi Commento
Linea Traguardo
Joshua Ruehlig
Membro da: 14/01/2010
503 Reputazione
4 Guide realizzate
Cal Poly, Team 11-4, Forte Winter 2010 Membro di Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membri
8 Guide realizzate
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 8,945
