Introduzione
This guide will show you how to remove the motherboard on a Motorola V3c.
Cosa ti serve
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Pull out the motherboard.
You may also now replace the bottom lower casing
Altre 6 persone hanno completato questa guida.
