Introduzione
The purpose of this repair guide is to show how to replace the lower outer casing.
Parti
Nessuna parte specificata.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Pull out the motherboard.
You may also now replace the bottom lower casing
Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
