Salta al contenuto principale
Motorola Razr V3 Primary Speaker Replacement
Cosa ti serve
  1. Motorola Razr V3 Primary Speaker Replacement, Battery: passo 1, immagine 1 di 2 Motorola Razr V3 Primary Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Primary Speaker Replacement: passo 2, immagine 1 di 2 Motorola Razr V3 Primary Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Primary Speaker Replacement, SIM Card: passo 3, immagine 1 di 1
    • Remove the SIM card by pulling it toward the top of the phone with your thumb.
  4. Motorola Razr V3 Primary Speaker Replacement, Antenna: passo 4, immagine 1 di 1
    • Unscrew the two 5mm T6 Torx screws form the phone.
  5. Motorola Razr V3 Primary Speaker Replacement: passo 5, immagine 1 di 1
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
  6. Motorola Razr V3 Primary Speaker Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
  7. Motorola Razr V3 Primary Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
  8. Motorola Razr V3 Primary Speaker Replacement, Primary Speaker: passo 8, immagine 1 di 1
    • Using the spudger, pry up the primary speaker from the phone.
    • The speaker is magnetic and might stick to the board.
Conclusione
Cal Poly, Team 3-46, Amido Spring 2013 Membro di Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,136
