Introduzione
By following this guide you will remove the motherboard of the device. You may need to do this if your phone wont turn on and all other parts are still functional.
Cosa ti serve
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Remove the SIM card by pulling it toward the top of the phone with your thumb.
Use a spudger or blue opening tool to pry the motherboard away from the back casing.
Altre 3 persone hanno completato questa guida.
Un commento
Step 7 seems wrong to me. I almost broke my phone following the instructions.
To remove the antenna, you remove the two black plastic/rubber stoppers by prying them out. Then you have access to the two tabs underneath the stoppers. There are also tabs on the clear housing than hook into the bottom of the tabs on the main casing used to hold the two parts of the case together. I started on one side and gently went across, prying the tabs up.
