Salta al contenuto principale
Motorola Razr V3 Camera Replacement
Cosa ti serve
Panoramica Video
  1. Motorola Razr V3 Camera Replacement, Battery: passo 1, immagine 1 di 2 Motorola Razr V3 Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Camera Replacement: passo 2, immagine 1 di 2 Motorola Razr V3 Camera Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Camera Replacement, Upper Casing: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 Camera Replacement: passo 4, immagine 1 di 1
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 Camera Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
  6. Motorola Razr V3 Camera Replacement, Camera: passo 6, immagine 1 di 2 Motorola Razr V3 Camera Replacement, Camera: passo 6, immagine 2 di 2
    Compra
    • Use tweezers to flip up the ZIF tab on the camera ribbon cable socket.
    • Gently pull the camera ribbon cable out of the ZIF socket.
  7. Motorola Razr V3 Camera Replacement: passo 7, immagine 1 di 1
    • Using a pair of tweezers gently grab and remove the camera from the phone.
Conclusione
Christian
Membro da: 04/18/13
224 Reputazione
2 Guide realizzate
Cal Poly, Team 3-46, Amido Spring 2013 Membro di Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,999
