Salta al contenuto principale
Motorola RAZR Maxx HD Headphone Jack Replacement
Cosa ti serve
  1. Motorola RAZR Maxx HD Headphone Jack Replacement, Screen Removal: passo 1, immagine 1 di 2 Motorola RAZR Maxx HD Headphone Jack Replacement, Screen Removal: passo 1, immagine 2 di 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Headphone Jack Replacement: passo 2, immagine 1 di 2 Motorola RAZR Maxx HD Headphone Jack Replacement: passo 2, immagine 2 di 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Headphone Jack Replacement: passo 3, immagine 1 di 2 Motorola RAZR Maxx HD Headphone Jack Replacement: passo 3, immagine 2 di 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Headphone Jack Replacement: passo 4, immagine 1 di 2 Motorola RAZR Maxx HD Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Headphone Jack Replacement, Headphone Jack: passo 5, immagine 1 di 1
    • Use the Torx T5 screwdriver to remove two 4.0 mm screws on the cover of the headphone jack in the upper right corner.
  6. Motorola RAZR Maxx HD Headphone Jack Replacement: passo 6, immagine 1 di 2 Motorola RAZR Maxx HD Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Using the spudger tool, release the ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  7. Motorola RAZR Maxx HD Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Using the pointy end of the spudger, gently pry the headphone jack from the motherboard and remove it.
Conclusione
David Twyman
Membro da: 02/03/15
135 Reputazione
1 Guida realizzata
Cal Poly, Team 8-40, Amido Winter 2015 Membro di Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 320
