Salta al contenuto principale
Motorola RAZR Maxx HD Front-Facing Camera Replacement
Cosa ti serve
  1. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: passo 1, immagine 1 di 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: passo 1, immagine 2 di 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 2, immagine 1 di 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 2, immagine 2 di 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 3, immagine 1 di 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 3, immagine 2 di 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 4, immagine 1 di 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 4, immagine 2 di 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Front-Facing Camera: passo 5, immagine 1 di 1
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
  6. Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 6, immagine 1 di 3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 6, immagine 2 di 3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 6, immagine 3 di 3
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
  7. Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 7, immagine 1 di 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: passo 7, immagine 2 di 2
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
Conclusione
Jacob Syage
Membro da: 02/01/15
284 Reputazione
2 Guide realizzate
Cal Poly, Team 8-40, Amido Winter 2015 Membro di Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 289
