Salta al contenuto principale
Motorola RAZR Maxx HD Battery Replacement
Cosa ti serve
  1. Motorola RAZR Maxx HD Battery Replacement, Screen Removal: passo 1, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement, Screen Removal: passo 1, immagine 2 di 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Battery Replacement: passo 2, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement: passo 2, immagine 2 di 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Battery Replacement: passo 3, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement: passo 3, immagine 2 di 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Battery Replacement: passo 4, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement: passo 4, immagine 2 di 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Battery Replacement, Circuit Board: passo 5, immagine 1 di 3 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: passo 5, immagine 2 di 3 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: passo 5, immagine 3 di 3
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
  6. Motorola RAZR Maxx HD Battery Replacement: passo 6, immagine 1 di 1
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
  7. Motorola RAZR Maxx HD Battery Replacement: passo 7, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement: passo 7, immagine 2 di 2
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
  8. Motorola RAZR Maxx HD Battery Replacement: passo 8, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement: passo 8, immagine 2 di 2
    • Using tweezers, remove the back facing camera cover.
  9. Motorola RAZR Maxx HD Battery Replacement: passo 9, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement: passo 9, immagine 2 di 2
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  10. Motorola RAZR Maxx HD Battery Replacement: passo 10, immagine 1 di 1
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
  11. Motorola RAZR Maxx HD Battery Replacement: passo 11, immagine 1 di 3 Motorola RAZR Maxx HD Battery Replacement: passo 11, immagine 2 di 3 Motorola RAZR Maxx HD Battery Replacement: passo 11, immagine 3 di 3
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
  12. Motorola RAZR Maxx HD Battery Replacement, Battery: passo 12, immagine 1 di 2 Motorola RAZR Maxx HD Battery Replacement, Battery: passo 12, immagine 2 di 2
    • Wedge the spudger tool under the battery to remove it from the back case.
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 8-40, Amido Winter 2015 Membro di Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Membri
18 Guide realizzate
Un commento
When putting it all back together, is it recommended to replace the pieces of tape to protect/insulate the connectors, or is that not necessary?
FreeMan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,448
